Some info on the BALDWIN BT7349 oil filter!!
Old Dec 3, 2009 | 10:48 PM
justin mcfall's Avatar
Lightbulb Some info on the BALDWIN BT7349 oil filter!!
As far as filters go I believe Mopar has Fleetguard with Mopar lableling.
I use a Baldwin BT7349 oil filter on my 92 dodge cummins, The casing is STRONG, great filtering and media, overall construction is excellent. Heavy casing and good specs, Absolute Beta ratio on it is 30 microns, the regular common Fleetguard for my cummins I believe is 40 microns. The Baldwin BT7349 is for Dodge Cummins 1998 and below models, if your cummins is post 98 I can find the right number for you if you like. This BT7349 Absolute Beta ratio is about similar to the Fleetguard Stratapore version at about 30 microns, that Fleetguard Stratapore was about $15.00 the last time I bought one. I dont know if Mopar filter will be stratapore and I doubt , Mopar will probably ding about $14.00 compared to Baldwin.
IMO Baldwin has second to none service/tech staff, I have absolute beta ratios on every Baldwin I use on every vehicle, they will give you any info you want via email, flow rates, bypass pressures etc., just ask, if required they will phone you with more info first hand too, great company and quality. Their website will give most info except absolute beta ratios, get that via email. They have excellent "application" and "cross reference" resources. It is American quality, not offshore [censored] made of cardboard.
I get my Baldwin filters at Serv/Agro in Lethbridge or Medicine Hat, best prices there, look for the 15% off sale in spring at seeding season, I buy $300.00 worth oil filtes and air filters, check out Baldwin air filters and after you compare a Baldwin air filters quality and construction to what you may have in your truck now you will buy Baldwin. I pay about $8.00 Canadian for the BT7349 on sale and $32.00 for the big round air filter, you can also get Baldwin at Aclands/Grainger too. Dont let the very competitive low prices of a Baldwin fool you, they are TOP quality and the first time you pick one up the first thing you notice is the weight of them, then the fine professional machining detail and construction, they are are substantial filters. Serv/Agro is also the Esso dealer where you can get XD3 products.
Old Dec 4, 2009 | 06:57 AM
MikeyB's Avatar
Thanks for the info. I'm also running Baldwin filters.
MikeyB
Old Dec 4, 2009 | 07:22 AM
RiverRat2's Avatar
MikeyB
+3!!!!! Fuel & Oil,,,, wasnt aware if they make an air filter for my 3rd gen,,,,,
Old Dec 4, 2009 | 07:48 AM
Hvytrkmech's Avatar
I have my entire shop on Hastings filters, including my pov. Baldwin and Hastings are the same company. I run a LF515 dual flow high velocity filter on all my N14's. It filters down to 10 microns absolute. I have been very happy with their customer service. I get a large volume discount from them. The LF608 that i use on my Dodge costs me $3.00.
Old Dec 4, 2009 | 08:54 AM
I found this info on Bob Is The Oil Guy..Good info on Micron Ratings for the oil filter..
Old Dec 4, 2009 | 09:07 AM
AH64ID's Avatar
The Mopar filters can be any of 3, IIRC, different manufacturers and are paper filters. They are 35um absolute. The Fleetguard stratapore filters are 25um absolute and are a cellulose media. Then their are Amsoil/Donaldson filters which are nano-fiber and are 15um absolute.
I run Donaldson oil filter, Amsoil air filter, and a combo of Baldwin/Cat fuel filters.
The Baldwin fuel filter is the best you can buy for the HPCR stock filter bowl. (in fact it fits 2nd gen too).
pcgym
Apr 29, 2010 07:46 PM
Diesel Newbie
17
Oct 26, 2009 04:37 PM
beardedone
Oct 14, 2008 07:33 AM
justin mcfall
May 21, 2008 07:53 PM
Kevin Krieger
Dec 23, 2006 11:25 PM
