SO or HO
SO or HO
This may be a dumb question but how can you tell if you have the SO or HO engine. i have an early 03 6spd. i looked on the valve cover but i didnt see anything, its the 305hp engine. Thanks for your help. Daniel
No.
Previous to 2004.5 Dodge/Cummins had two different output motors; HO and SO motors. After 2004.5 there was only the "standard output" motor of 325 HP / 600 ft. lb.
Pre 2004.5 the HO motor was rated 305 HP. You have the HO motor (305 HP / 555 ft. lb). The pre 2004.5 SO motor was only attached to the older automatics (47RE). You have a good motor!
03 SOs were rated at 250hp/460tq. The California SOs were 235hp/460tq.
03 SOs started out with only the 47re available but once those trannies were exhausted then they started making them with 48re's. There were also some 04 SOs made with the 48re. If your engine has the 305 on the tag then it is an HO. If it is a 6 speed it is an HO. If it has a 5 speed then it is an SO.
Starting in 04.5 they were all HOs. Even though there is no longer an SO offered they are all still considered HOs...
I don't know about the ETH question.....
