silencer ring issues
ok... so after reading the other thread about the effects of removing the silencer ring, i decided to give it a try on my 04 with the 305hp. at last count i had three bloodied knuckles, two snapped screwdrivers, and various scrapes and scratches on my arms. i have always considered myself to be fairly mechanically inclined.....
sorry problem with the computer, long story short, how do you get that snap ring out??? the opening in mine is right at the top and i cant get anything in there to get that ring out. i have managed to scrape up my turbo housing however. any help here would be greatly appreciated.....
Originally posted by mikal711
mine poped right . the split in the ring is at the top just catch the edge and it comes right out. also cut the baffles out of the hose betwine the turbo and filter
My truck needs to go to the dealer, and it's swapped back in.
Matt
You can build one cheaper than buying one the parts are 3-4 dollars @ Lowe's all you need is a section 4''PVC pipe 4''coupling glue um together and clean off the all off of the small PVC scraps . Thin paint it black. And your done.Good luck
Somebody mentioned to hold a mirror down under the turbo so you can see it better from above. Might have been hoot. Anyhow, I didn't have a small mirror -- so I tossed a rock down on a bigger one I didn't need and used a small piece of it to see what I was doing. Used a tiny screwdriver, the size a little bigger than people use to tighten up their glasses, to get under it in the gap where the ring ends join and it popped right out. No problems after I got the mirror.
~ David
~ David
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
