Sign of bad valve cover gasket?
Need some help guys. I threw a code yesterday ( p-2146 and a p-2149)
Someone told me that this is a possible sign of a bad vavle cover gasket. The code states that the 1-3 and 4-6 pistons shorted high or low. How could a bad valve cover gasket cause this?
Thanks,
Eric
Thanks,
Eric
DTR's 'Go to Guy'
OTHER DTC'S
With the scan tool, read DTCs.
Do you have any combination of DTC's P0201, P0202, or P0203?
Yes
Repair other DTC's first.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES/ENGINE CONTROL MODULE - DIAGNOSIS AND TESTING)
No
Go To 2
2. HIGH SIDE DRIVER CIRCUIT OPEN
Turn the ignition off.
Disconnect the ECM harness connectors.
Disconnect the Injector 1-3 harness connector.
NOTE: Check connectors - Clean/repair as necessary.
Measure the resistance of the injector high side driver circuit between the Bank 1 high side driver circuit in the ECM harness connector and the high side driver circuit in the injector harness connectors for cylinders 1-3.
Is the resistance less than 10 Ohms?
Yes
Go To 3
No
Repair the open high side driver circuit from ECM harness connector to the Injector harness connector.
3. LOW SIDE DRIVER CIRCUIT OPEN
Measure the resistance of the #1,#2, and #3 injector low side driver circuits between the ECM harness connector and the injector harness connectors.
Yes
Go To 4
No
Repair the open low side driver circuit.
4. HIGH SIDE DRIVER SHORTED TO LOW SIDE DRIVER
Measure the resistance between the Bank 1 high side driver circuit at the ECM harness connector and the low side driver circuit for injectors 1-3 at the ECM harness connector.
Is the resistance more than 100k Ohms?
Yes
Go To 5
No
Repair the High side circuit shorted to the low side circuit.
5. HIGH SIDE DRIVERS SHORTED LOW
Measure the resistance of the injector harness connector high side driver circuits to battery negative for injectors 1-3.
Yes
Go To 6
No
Repair the High side driver shorted low in the harness.
6. LOW SIDE DRIVERS SHORTED LOW
Measure the resistance of the injector harness connector Low side driver circuits to battery negative for injectors 1-3.
Yes
Go To 7
No
Repair the Low side driver shorted low in the harness.
7. HIGH SIDE DRIVER SHORTED TO VOLTAGE
Measure the voltage between the high side driver circuit in the engine harness and battery negative.
Is the voltage less than 1 volt?
Yes
Go To 8
No
Repair the high side driver shorted to voltage.
8. LOW SIDE DRIVER SHORTED TO VOLTAGE
Measure the voltage between the low side driver circuit in the engine harness and battery negative for cylinders 1-3.
Yes
Go To 9
No
Repair the low side driver shorted to voltage.
9. LOW SIDE DRIVER CIRCUIT SHORTED OTHER LOW SIDE DRIVER CIRCUIT
Measure the resistance of each of the Bank 1 low side driver circuit to all other Bank 1 low side driver circuits at the ECM harness connector.
Is the resistance greater than 100k ohms?
Yes
Go To 10
No
Repair Low side driver circuit shorted to other Low side driver circuit.
10. LOW SIDE DRIVER CIRCUIT SHORTED IN INJECTOR HARNESS
Reconnect the disconnected injector harness connector.
Measure the resistance of each of the Bank 1 low side driver circuit to all other Bank 1 low side driver circuit at the ECM harness connector.
Yes
Go To 11
No
Replace the injector harness.
11. INJECTOR CIRCUITS SHORTED INSIDE ENGINE
Disconnect the injector through head harness connector.
Measure the resistance of each injector from the through head connector.
NOTE: Be sure to zero the ohm meter prior to checking the injector circuit.
Is the resistance greater than 0 ohms and less than 1 ohm?
Yes
Go To 12
No
Go To 14
12. INJECTOR
Disconnect the pigtail nuts from injectors 1-3.
Measure the resistance between the solenoid posts of each injector.
Is the resistance less than 1 ohm and greater than 0 ohms?
Yes
Go To 13
No
Replace the fuel injector or injectors.
13. INJECTOR HARNESS
Measure resistance of each circuit in the injector harness from pigtail side to injector harness connector.
Is resistance above 1 ohm?
Yes
No
Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure). (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
14. ECM
Reconnect the all injector pig tails harness connector.
Reconnect the ECM harness connector.
Reconnect the Injector harness connector.
Start the engine.
Did the DTC return?
Yes
Replace and program the ECM in accordance with the Service Information.
No
Yes
No
Go To 2
Yes
Go To 3
No
Yes
Go To 4
No
Yes
Go To 5
No
Yes
Go To 6
No
Yes
Go To 7
No
Yes
Go To 8
No
Yes
Go To 9
No
Yes
Go To 10
No
Yes
Go To 11
No
Yes
Go To 12
No
Go To 14
12. INJECTOR
Yes
Go To 13
No
Yes
No
14. ECM
Start the engine.
Did the DTC return?
Yes
No
DTR's 'Go to Guy'
Heres a picture to help along with the instructions. Hope it all makes sense. If not let me know. This is for P2146......P2149 is the same mweasurements just for the rear 3 injectors.
Thank you Sir
Thanks for the help!!! Pulled the injector plug for injector 3 and found a loose connection and debree inside. Cleaned the plug re-greased and connected it back together. Drove for about ten miles and the enginge light and codes all went away.
n5oxp
09-20-2005 06:19 PM
