Shock Install?
Old Jul 26, 2005 | 09:34 PM
Crabjoe's Avatar
Shock Install?
Can anyone tell me the process to replace the front shocks? I took a quick look and am not sure what the process is since the shock is in the middle of the spring.
Thanks
Old Jul 26, 2005 | 10:49 PM
Aloha's Avatar
The front shocks come out the top. Remove the lower shock bolt using a 21mm socket and wrench. Remove the upper shock mount nut using a 17mm socket or wrench. Then remove the three nuts that attach the upper shock tower to the frame. These are 15mm nuts. Installing the new shocks is the opposite of removal.
Aloha
Old Jul 27, 2005 | 01:18 PM
Crabjoe's Avatar
Aloha,
Thanks for the input. It's exactly what I thought the process would be but wasn't sure because I've never had to remove the actual shock mount in the past.
freight train
22
Mar 25, 2013 04:46 PM
stumpjumper
Aug 21, 2007 07:14 AM
VACHZHD
Apr 16, 2006 09:16 AM
Geico266
Mar 10, 2006 12:19 PM
Commatoze
Nov 24, 2003 05:34 PM
