-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Shift pattern on shifter turned side ways (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/shift-pattern-shifter-turned-side-ways-44827/)
schu May 22, 2004 04:28 PM
Anyone know how to turn the knob so the pattern is right side up again?
schu
mishkaya May 22, 2004 04:33 PM
The knob is a screw on type, you should just be able to turn it the way you would like it I would think.
Mishkaya
K2Cummins May 22, 2004 04:57 PM
You should be able to pry up the pattern on top of the knob and rotate it where you need it.
Garth in Albert May 22, 2004 05:40 PM
I'm not to sure about that one. I have noticed that on my truck the shifter knob slowly rotates all the way around. it takes about two months to complete the rotation. I think that it has something to do with the different phases of the moon.
spots May 22, 2004 07:57 PM
It is not the shifter knob moving. It is the little button on the top. Pry it out, cut a few notches in it, and put it back in. I did this with mine very early on and it has only rotated 1/4 turn in almost 50k. Some guys glue it in, some live with it.
fschiola May 22, 2004 09:28 PM
I think that's called bi lunar. :)
nickleinonen May 22, 2004 10:41 PM
mine had rotated from 9-3 [clock position] to about 11-5 in like 6,000 kilometers. now i have a nicer feeling shift knob home made #2 billard ball... much more comfortable
JoelCool May 23, 2004 01:28 AM
Mine was about 90 degrees off when I bought the truck. I simply applied a twisting motion with my palm as I drove down the road, and in a few hundred miles it's now straight again.
FuzzyDuck May 23, 2004 01:46 AM
Mine used to rotate, but I finally pried it out and put a dab of glue in the notch that it pops back into and popped it back in... Doesn't rotate anymore.. Just make sure to use something that can't cut the knob as you pry it out. I used a key..
Patrick Campbell May 23, 2004 10:26 AM
haha!
fanofthewolf May 24, 2004 01:37 PM
Well there's one more reason to get the auto ;)
schu May 24, 2004 02:29 PM
Ok, I didn't know it was just a little button... I didn't fitz with it much.... I'll put some glue in there.
Fanofthewolf, what are you talking about, there are reasons for wanting an auto? :)
Hoss May 24, 2004 02:54 PM
The "rotational shift device" is a feature included on the truck to help familiarize the driver with the truck's transmission. It seems that by having the piece inside the knob rotate, the driver comes to know the transmission "forwards and backwards". Such knowledge tends to reduce grinding gears and therefore makes the transmission last longer. Any adjustments made to this device could potentially void your warranty. [eyecrazy]
And....Ford owns Cummins. ;)
fanofthewolf May 24, 2004 03:30 PM
Ouch!! schu that stung, good, but stung :D [laugh]
schu May 24, 2004 03:33 PM
Heh, I figured I would fling it back at ya!!!
