Rear Engine Seal and Tranny Front Seal #s
I am at 205,000 miles and expecting my original clutch to let go before too long. Still holding fine now but jeez, how long can this thing last?
I ordered a DD3250 from Larry and while I am in there, I am thinking I should do the rear engine seal and probably the front tranny seal too. What about the front bearing in my NV5600? Anybody that long on their 5600 and taken a look in there? If anybody has the part numbers on these seals and bearing, and best place to get them, it would be greatly appreciated. Thanks! |
I replaced my front seal on my tranny but I can not remember the part #s, I got that part from the dealer. the engine I would get one from cummins if you call them you will need you engine s/n. I did that work at about 155,000mi.
rear main
A must while everything is out, when they installed my trans they checked it wasn't leaking six months later it started leaking, had to have it replaced![coffee][coffee][coffee]
bump, anybody with part numbers? What about the input shaft bearing?
Thanks, |
