rear diff on 3500
Old Apr 2, 2003 | 05:47 PM
papaduck's Avatar
rear diff on 3500
Just changed the oil in the rear differential on my 03 (15,000 miles) and got a surprise. I had expected to need to clean the silicone rubber and was prepared to use the mopar silicone that seals in oil on the back plate. The new axel uses a gasket! I was miles from any dealer and had to be careful and reused the old gasket. So far no leaks. <br><br>I used Penzoil GL-5 75w-90 synthetic as a replacement oil. Anyone have any comments on this oil. It was all I could find in this area of Arkansas.
Old Apr 2, 2003 | 08:05 PM
Casey Balvert's Avatar
Re:rear diff on 3500
It is reusable. It is metal with a rubber bead on it. No leaks after changing my oil. What hurt most was the price of the oil.
Casey
Old Apr 3, 2003 | 07:46 AM
papaduck's Avatar
My dealer took about an hour to find the mopar part number and priced at $16 a qt. They didn't have the oil in stock. The Penzoil was under $7 at local discount store. Some of the parts stores had prices a little higher on other brands but none had 4 qt.<br><br>The gasket was metal, rubber covered with two beads. It did not stick and came loose under its own weight. This morning there is no leaks.<br><br>The manual does not list the oil capacity but for those interested it is 7.85 pints.
Old Apr 4, 2003 | 08:40 AM
Mopar_Mudder's Avatar
Since when did they ever use silicone to seal the cover on, from the factory any ways, always been gaskets that I know of.
Old Apr 4, 2003 | 01:53 PM
spots's Avatar
dunno about DC but Ferd used silicone for many years...
Old Apr 4, 2003 | 02:38 PM
gofastman's Avatar
;DMy truck I have changed it every 12000 miles, I do alot of pulling of Campers, so I keep it changed often.<br>From brand new it came with no gasket, It had the Mopar Grey silicone.<br>If it was supposed to have a gasket, I think they must have forgotten.<br>I run 80-90 year around, I have thought about using the synthetic gear lube, but it is pricey, and I dont know how well it will hold up under the pressure of pulling heavy loads.
Old Apr 4, 2003 | 09:29 PM
My 97 used RTV silicone as a sealer. The new one uses a metal gasket with a rubber bead and is reusable.<br><br>Casey
afate45
Jun 7, 2014 12:08 AM
banana
Dec 1, 2009 11:44 PM
shehi2003
Dec 16, 2006 12:35 PM
LT500Rider
Nov 30, 2006 10:46 AM
The Domie
14
Nov 30, 2004 08:29 AM
