RAM 4x4 system truly disappoints
#31
Something is definitely wrong with your 4wd if neither front tire was spinning. Get it checked. Try engaging 4wd on dry pavement and turning sharply left and right in a parking lot while going slow. Your truck should kinda hop if 4wd is engaging properly. With that said, don't do this to much because it puts lots of stress on the driveline components, just do it for testing.
I have a dually also and without 4wd or lots of weight it doesn't like to go real well in snow. Now put my 4500 lb. camper in the bed and that's a different story.
#32
In 4wd you should have had a front tire spinning. If one front tire and one rear tire were spinning they should be spinning at the same speed. If 2 rear tires and 1 front tire are spinning the front tire will spin twice as fast as the rears
PLEASE ELABORATE.....
#33
Originally Posted by RAW
I was extremely disappointedwith the 4x4 system in the RAM the other day.
I was leaving my property in the NC mountains. True, there was about a foot of snow on the ground.
And the truck made it part of the distance
But then I slid into a ditch, where the RAM just failed to extract itself.
I suppose I could have blamed my lack of chains and a shovel, but . . . the biggest problem was that the truck sent 95% of the power to the wheel with the LEAST traction!!! I had the system in 4LO, and almost every drop of power went to the left, rear set of wheels. It was absolutely pathetic. The front wheels would just barely twitch before giving it up.
This experience absolutely confirmed that I will NOT be selling my other 4x4 truck any time soon. The RAM on the other hand . . . . well, it might be looking for a new owner once I finish moving to NC.
I'm pretty sure that I've read here that there isn't a drop-in locker available for our trucks. Is that true??
With what I've described, is it possible that something isn't working properly? Or is this how the system functions?
#34
Raw, Your neighbor seemed well equipped for the task! I'm sure your not a moron or at least not more of a moron than the rest of us . I was giving you some dually advice from someone who lives in snow 4 or 5 months of the year. In a situation like I see in the additional pictures....you would have done better in 2wd with the truck in 1st to control speed. In 4lo its like having all four tires locked up. In 2wd the fronts still have steering and if you can minimize braking the fronts are free to steer. Your Cheapest solution as you mentioned is a set of good dually chains. $250. and you will be able to anywhere anytime. If you switched into 4lo....were you in N and did you here it CLUNK into 4wd. If you didn't hear it clunk then it didn't get there. If you were moving faster than 4mph it won't go into 4 lo when you are in N. If you quickly swithch from 2wd to 4 Lo in park or above 4 mph you get 2wd not 4 hi. If that doesn't work what year is your truck and how much do you want for that obvious POS no good truck. ks
#35
Muted User
Location: "The Peoples Republic of Illinois".....behind enemy lines
Originally Posted by Cargun
If 2 rear tires and 1 front tire are spinning the front tire will spin twice as fast as the rears.
NOT They'll be turning the same speed!!!
#37
When I started the truck that morning, I let it run through its fast idle. Then I put the clutch in, selected 4LO, waited for the light to stay solid (and listened for click of actuator or whatever--not a real clunk though). Then I put it in first and slowly ascended the hill up to my house-site from my shop. On the way up, the front did the usual skipping on the sharper switchbacks. Stopped at house-site, and I waited while one of my passengers took a picture. Then I put it back into first, gave it a little go juice, and then just let gravity start pulling the truck down the driveway. And in 4LO, it was a good speed--not too fast, but steady forward progress.
I steered to keep in the middle of the road, but the truck slid sideways into the ditch. I tried to drive out of the ditch, but it kept sliding back in. Then the truck just stopped. Then it was just the one wheel spinning. Tried reverse. Tried forward. Tried steering left and right while accelerating. Put in clutch, tried 4HI forward and reverse. Nothing.
I will be trying to make an appointment at a dealership soon. Hope it isn't expensive.
#39
That's not correct.
Imagine you are driving straight on dry pavement. All tires are turning the same speed, correct?
When going around a corner the outside tire travels a larger arc so it must speed up. That's the job of the differential. Because of the differential gears the speed is proportional between the axles. If the outside tire speeds up the inside tire has to slow down.
Now, if one tire is completely stopped the other will spin at double the speed.
#40
In Montana we get snow once in a while. Over 20' anually to be exact. Duallies don't do well in snow here. Any logger, farmer/rancher, hunter, etc. will not have a dually in this country. The rears just don't have enough lbs per sq in in low traction situations as you found out. A lot depends on the snow as well. Duallies can do ok in dry snow. In wet snow or in crusted snow they can't get out of their own way. Also, many srw's need good tires to do any kind of job getting around in those conditions as well. I think you were asking way too much from that truck in my opinion.
Stock tires+snow=bad
(stock tires+dually)+snow=really bad
#41
Originally Posted by bigdav160
That's not correct.
That is correct.
#42
If something is broke or whatever that will sure make a difference.
In my experience:
It really helps to put chains on the front with the dually so you can steer and get pulled thru the snow. I have pushed snow with my front bumper in my dually and it did just fine but the story that follows was nerve racking.
I was pulling my gooseneck trailer with 3 horses, 500lb of feed,15 bales of hay and 100gallons of water going to hunting camp. The front tires were chained up and I was in 4 low 3rd gear @ idle just letting the engine pull me along. The big problem was the narrow forrest road and slight slant in the curves the trailer would slide down until it stopped against the trees. I was way in over my head and by myself in the middle of the night, luckily I only had a 1/2 mile of this and got to a spot where I could turn around w/o stopping so I could head back down. 3 hours later and 4 miles I was sleeping.
In my experience:
#43
Location: somewhere in northwestern ohio....Mansfield, Oh
My son is going to college in Mars Hill about 30 miles north of Asheville NC he keeps telling me he is wearing shorts and it is bright and sunny out . It would not be the first time he pulled my leg a little , I think I will send him a copy of your pictures . He runs on thier cross country and track team and is majoring in Biology at the college . My wife and I both love the area one of the prettiest we have seen in our travels . When you put the Smokey Mountain's , Appalachian trail and the Blue Ridge Parkway all in one spot it has got to be great . Sounds to me like you have a transfer case problem and it is time to visit the dealer. That is the only way you would not have a front tire spin in 4x4 that I can think of . Most likely something in the electric shift . Mine has worked flawlessly and I' am building up some confidence in it . I have drove a lot of 4x4 some were better some worse and our Cummins fall close to the middle of the road . With the amount of snow you get down their , according to my son I wouldn't change to much on your truck just get fixed what is not working .
#44
The only time I have been stuck (in snow), is when I have broke through a hard drifts and ended up high centered after pushing about a 9” hard crust with my bumper for about a 150 yards (that’s deep when you consider I have 37's & a 5 " lift). But with a little gentle persuasion about 95 % of the time I can get my self out. These trucks can break some serious trail if you have good aggressive tires on & some weight to put the power down.
#45
Jason
I'm just wondering, cause if so I am going to lock the front of my jeep and lower my overall gear ratio, and open up the back of my dodge to raise it. I could save a ton of money that way.
