Questions on a 2006 dually
Gentleman I found a 2006 Laramie Dually 6 speed manual with 123k miles
1 owner Truck ranch in southern Ut. It has a K @ N air filter Not happy about that. Tapped exhaust manifold but not hooked up to gauges Raptor 150 fuel pump Should I pull the intake to the turbo to view the Impeller to see if I can see any damage or what would be the best way to check if much dirt got by. Raptor 150 would someone use this for just a better fuel pump?? Anything else to look for the Truck inside and out looks immaculate. price 27k good bad or ugly?? Thanks MO |
Top of my head, other stuff to look at.
Front drive shaft - ujoints and diff seal. Rear drive shaft - ujoints, steady bearing, diff seal and tranny seal. Front axle trans ujoints, ball joints, and axle diff seals and fluid level. Rear axle seals, fluid level. Rear brake rotors - badly worn inside? Front steering upgrade? Y-style original or T-style upgrade. Trans cooler rad - wet up top? Multifunction switch warranty to 150K km? Cluster tach. TIPM - Headlight, taillight issues. Manual tranny bonus - auto has issues. Fuel filtration, stock or upgraded? |
It is a Manual 6 speed
It just has stock fuel filters What is the easiest test for the drive shafts Thanks 55 sid |
Check to see that climate control works well in all modes, too.
I have an 06 dually Laramie stick, and it's been a great truck. I don't think I'd give 27k for the one you describe, though. Maybe seller would be open to an offer. |
