PS silver
so the book for my 5.9 '05 sez no fuel additive is required but i put in PS grey on each fill up. does the board really think PS helps keep the injectors clean and help prolong the life of the injectors?
i like to think i am helping the injectors but just don't know. whatcha think? david socal |
well.....
I use the PS gray/silver also. I dont run it every tank though, more like every 4th or 5th. Honestly cant tell a difference, but it makes me feel better, LOL![laugh]
ran a couple of tanks with lucas upper cylinder lubricant, and injector rattle is non-existant, truck runs smoother, and exhaust smells better. it is also the only fuel additive i've used, that doesn't have a 'solvent' smell to it.
There was now ULSD in 05. Now all diesel (on the west coast anyway) is ULSD. If you plan on keeping your truck, I wouldn't run it without an additive. I would also recommend using Baldwin 7977 FF's: they are 5 MIC. Injectors and CP3s are big $.
Nick |
If your buying high quality diesel then you most likely only need to use PS a few times a year and not in every tank. My self I use Lucas as I feel it does a much better job then PS ever did in my truck and I see a small gain in mpg when I use it. I would also agree to use the Baldwin 5 micron fuel filter or the Fleetguard Stratapore filter if you can not get a Baldwin or even a Mopar if that is all you can get. FYI, many of the other brands sold at parts houses are still 10 micron and you need to use a 7 micron or smaller fuel filter.
Originally Posted by DBLR
(Post 2125312)
I used PS every other tank and had to replace my injectors. I think its crap but thats just me. I use BG 244 couple times a year, although its $40 a quart, I think its worth it!
You might find this thread from another web site interesting. It quotes an independent study comparing the lubricity of diesel fuel additives.
http://www.dieselplace.com/forum/sho...d.php?t=177728 |
Originally Posted by Bigiron
(Post 2126575)
Originally Posted by chipmonk
(Post 2126704)
this was discussed a while back- there are several products that did well in this test, that are more than 50% by weight petroleum naptha (about twice as much as sea foam), which is a strong solvent. products that contain that much of a strong solvent may not be the best thing for injectors, and i'm not sure how a strong cleaner/solvent can add to the lubricity of fuel. there are many that say not to run any product that is more than 20% solvent (naptha) on a regular basis.
I run 16oz of PS with 16oz TCW3 every other tank.
MikeyB |
(Post 2127281)
What ever the products that did well in this test contained, they were good lubricants since that is was what the test was for. Even is some did contain 50% naptha, that leaves a lot of room for lubricant.
