| jordankeck |
Nov 10, 2025 07:21 PM |
So I rented a DRBIII and went though the "MISCELLANEOUS" option of the ABS section and updated my revs per mile to correct my speedometer. When I restarted the truck I no longer had the flashing yellow ABS light, but after driving down the road a short distance both the BRAKE and ABS lights come on solid. I am still getting a code 37 for the rear axle sensor. I had previously replaced the sensor with no affect on the code 37. I am now wondering if I may have crud built up in the axle near that may prevent the sensor from picking up every pass from the ABS tone ring. I also have an issue with cruise control where the truck acts like it is hunting for the speed instead of maintaining. Has anyone ran across issues like this and a code 37?
