P2121 p2122 ***
Howdy y'all I got these codes with a erratic throttle response. I just put new apps in today still running like ****. Anyone have this problem before on these dodges?
Sir, you need to add the year of your Dodge Truck so the members can help you.
------- John_P |
2004.5 cr
I have moved your thread to the proper section so the other DTR Members can better help you.
------- John_P (Admin) |
I too would like some help. Been trying to fix my dads 07.5 6.7 that is doing the same thing. Installed new apps. I did read that the sensor is sensitive to sufficient power supplying it, so we are getting batteries load tested tonight.
Check your battery cables, especially the ground cables.
