-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   p0088 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/p0088-312295/)
DragonSlayer May 26, 2013 07:48 PM
p0088
Got the **** code........pulled and replaced the fuel filter today, no signs of algae. I'm going to buy a FCA when the stores open. I hope that fixes the cel. [duhhh]
DragonSlayer May 28, 2013 09:31 PM
Pumped out the bad fuel from tank to replace with fuel from another location. While priming the fresh fuel in, I cranked and got aanother code. The truck ran for maybe 30 seconds and died and would not start. New code is p0628. Lift pump low voltage. I can jump the pins in the fuse box and make the pump run, but it will not run with relay installed. Any ideas?[duhhh]
cdennyb May 29, 2013 04:44 PM
Did you swap out the "bad" relay for a "good" one and see if that's the issue?
DragonSlayer May 29, 2013 06:49 PM
Yes sir, we did the relay shuffle! I think my pump died while I was pumping the ful out with it. I have no way of knowing if thats the orig pump or not.
