front end knockin but not in 4wd, U-Joint?
Old 04-17-2012, 11:39 PM
jellyroll's Avatar
My O6 4wd with 142K has begun knocking from the drivers side front. I jacked it up, spun the wheels and the knock sounded as if it was coming from somewhere between the u-joint and front dif. Upon searching the forums I thought it might be the u joint, but when I engage the 4wd it goes away. Any thoughts, could this still be the U joints? Anyone experience anything similar? got to take it in Thursday for the multifunction indicator TSB so I was hoping to have an idea of what it might be prior to that
Old 04-18-2012, 09:42 AM
jhenson's Avatar
If you got 142k out of your stock u-joints...you're a lucky guy!! Most all of mine gave up the ghost starting around 30k miles. Still a pretty good chance your joints need to be replaced.
Does the knocking seem more pronounced while turning....any squeeking? Check your balljoints as well and make sure they aren't shot.
Old 05-03-2012, 06:28 PM
jellyroll's Avatar
no additional knocking when the steering is at full lock. if its the u joints why would it cease when 4wd is engaged? shouldn't it continue to make the knocking sound?
Old 05-04-2012, 08:38 AM
Jeff in TD's Avatar
I suppose if under load it might be quieter? If you look very closely, is there any reddish grit around the seals of the U joint? May be only on one cap.
Old 05-04-2012, 10:48 AM
jhenson's Avatar
I still say it's the axle joint!!
Old 09-29-2012, 10:35 AM
Itsmejoe231's Avatar
I just started experiencing this exact same thing. Did anyone find what the problem was?
Old 09-30-2012, 08:10 PM
jellyroll's Avatar
Jhenson was right....it was the u joint. Check your bearing while replacing it mine when out 1300 miles later
Old 10-02-2012, 09:04 AM
jhenson's Avatar
Glad you fixed it. Sometimes certain problems can be a real pain to figger out!!
dieselgirl01
02-27-2011 09:09 PM
Midnite Warrior
01-12-2009 02:11 PM
wcbcruzer
09-05-2008 08:36 AM
LockedandLoaded
01-07-2008 10:26 PM
PurNLoud
02-13-2006 11:57 AM
Quick Reply: front end knockin but not in 4wd, U-Joint?
