-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Over boost condition (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/over-boost-condition-191731/)
Tedonlin150 Feb 11, 2008 10:00 PM
I have a 2003 SO with an aFe stage I intake and a Magnaflow 4" exhaust. I checked for fault codes and it gave me P0234 which means over boost condition. What does this mean and is this bad? Thanks
bluechrome Feb 11, 2008 10:01 PM
You have a Stock turbo, any gauges any boxes?
Tedonlin150 Feb 11, 2008 10:06 PM
The turbo is stock and no gauges, and no boxes as far as i know. I bought the truck used so i don't know what the other owner did. I checked for codes a few days ago and P0234 did not come up.
RamWheelsBy4 Feb 11, 2008 11:10 PM
Did the CEL light come on? Did the truck go into limp mode and run very slow with no power?
Need to see if you can fill out your signature with all truck information.
Tedonlin150 Feb 12, 2008 03:57 PM
No, the light did not come on and it did not go into limp mode. for some reason my signature doesn't show up but i have the truck info in the first post.
Tedonlin150 Feb 12, 2008 04:17 PM
This is a test to see if my signature works
Dodgezilla Feb 12, 2008 05:37 PM
The truck does not go into limp mode with the Overboost code. It does if you get the Low boost code. Seems backwards to me but I have had several of both codes recently and I am now an expert.....
Maybe your wastegate is stuck closed causing you to get too much boost and that's throwing the code. Did you happen to do a wide open throttle run anytime recently?
Tedonlin150 Feb 12, 2008 08:51 PM
Yeah, sometimes i just get the urge and put the peddle to the floor and hold it there till about fifty or sixty. Over boost doesn't hurt anything though does it? Is there a sound that the waste gate makes when it opens? If it does make a sound I probably wouldn't be able to here it anyways cause of the intake ad exhaust I have.
bluechrome Feb 12, 2008 09:08 PM
I beg to differ. Ask Bob Wagner[laugh] It's happen to me in three pulls and the truck automatically goes to 2000rpm and cuts the fuel big time!!! A overboost Condition.
if you are not running a fueling box you should be fine and I would not worry about over spining the turbo IMO
Dodgezilla Feb 12, 2008 09:23 PM
Well, I got the Overboost code a couple times when I pulled my boost fooler off the truck. It ran exactly as it did prior and did not lose any power. My truck is the Devil Truck so maybe it is just backwards......
bluechrome Feb 13, 2008 05:04 PM
HA Ha LOL[laugh]. Maybe This condition is the only form of throwing a 6-speed into Limp!
