One more SRW to DRW tread.
Hi,
I`m a new member from Norway.
Been searching diffrent forums for info in SRW to DRW builds, but I cant find anyone who know if the rear hubs will fit from DRW to a SRW aksel.
It`s not possible to get a DRW aksel here in Norway, and shipping a complete aksel from US would cost alot.
So if I could just get the hubs and the driveshafts from a DRW then it would save me alot of $ in shipping costs.
So is there anyone who knows for sure that the aksel housing are diffrent?
Regards Lars
Regards Lars
Received 1,637 Likes
Hey Lars
We call it an axle, not an aksel. Just not to confuse the fellas here, as I was a moment ago.
What year truck you working on? What series axle? Dana 80?
It's not that simple to just swap hubs. A dually axle is much wider than a single wheel. So let's just say you did swap hubs now when you went to install your inside tire on the new hub your tire is going to hit your leaf spring before it seated on the new hub.
I`m saking if anyone knows this, not what anyone thinking. I need to know. lol
They do make spacers to install on your single wheel axle. It does not give you a higher weight rating with them but it does give the better stability of having duals. I have seen them on trucks but I personally would not use them.
A 2004 Dodge 3500 would have originally have had a AAM 11.5inch rear axle.
The SRW and DRW axle housings and hubs are different.
Many parts are identical like the differential parts and brake parts.
SRW 11.5" rear axle:
DRW 11.5" rear axle:
Do you really need the DRW in the first place? Is there a weight issue over there? I don't know the laws there but if you need more payload, can you get a GVM increase with say airbags and higher rated tyres on the SRW? I have read that the SRW is better in snow too.
I don`t have too, I just want to.
Doing a full rebuild of the truck, just love the 10 lug wheels.
