Oil pan gasket and sealant
Well, after 248k miles, she started to leak. (that sounded bad) lol Anyway. nothing major, but I like to nip it in the bud before the leak gets bad. Have two questions.
1st, the cummins manual says to use sealant part number 3164070 which is Loctite 5999 Flange Sealant on the joints in 4 places. Doesn't call but for a 1/16 inch bead there. This sealant I bought is 41.00. I haven't cracked it yet. Is there something equivalent that is cheaper? I am a frugal a.. as my friends have said. I also have Loctite 5699 Grey. Is this about as strong as the 5999? Maybe you sealant gurus can chime in.
2nd of all, I was told on the standard six cylinder oil pan gasket to install it dry and to torque capscrews @ 21 ft-lbs which is 248 in-lb in the Cummins B series manual. Is this correct?
Update: My truck is a 2005
you can use RTV I also use copper coat spray on the pan gastet.It seems like after a while the pan will leak . I think Cummins has there gaskets made by Harley. every where you park they mark there spot
TheProspector
09-29-2012 10:47 PM
Common
08-24-2006 06:31 PM
TxDiesel007
07-24-2006 07:22 PM
Diesel-Dan
05-26-2004 04:42 PM
