Oil Overfull -Remove it?
Old Nov 13, 2003 | 09:24 PM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
My oil was changed for the first time and I think by the stick it is a couple of quarts over maybe? Up on the stick about 1/2 in. above full mark!
How can I remove some oil.....or should I let it ride?
Thanks 8)
Old Nov 13, 2003 | 09:46 PM
MikeyB's Avatar
Re:Oil Overfull -Remove it?
Did you ask how many quarts was used? When I changed my oil and added 12 quarts the oil level was above the full mark also.
MikeyB
Old Nov 14, 2003 | 12:45 AM
Dr. Evil's Avatar
A 1/2 inch??? thats not very much, you'll be fine.
Old Nov 14, 2003 | 05:37 AM
spots's Avatar
Some have posted that overfilled oil will cause more smell from the breather tube. If this is a concern to you then you should take some out. Last time I changed my oil I left it 1/4 inch to 1/2 inch below the full marks, still in the hatch mark area. I use Rotella and found the smell was less. I change the oil every 12k and it has not used any between changes. You'd probably hafta pull the drain plug and let some out unless you have one of the fast drain valves.
Old Nov 14, 2003 | 07:29 AM
Hairy1's Avatar
Exactly how much oil should be added during a filter and oil change....? 2003 Model year
If it is over full now...? No damage will occur other than the vent breather smelling up! 8)
Old Nov 14, 2003 | 07:31 AM
Dr. Evil's Avatar
You could put a small hose down the dipstick tube and use a suction gun to remove some of the oil if you're concerned.
Old Nov 14, 2003 | 12:04 PM
Jonesey's Avatar
I start with 10-1/2 quarts and add if necessary to bring it up to the full mark. I have never added more than 1/2 quart for a total of 11 quarts.
Old Nov 14, 2003 | 03:16 PM
dodgedude361's Avatar
3 gallons, gets me right up to the full mark,thats including the quart in the oil filter.
Old Nov 14, 2003 | 04:10 PM
spots's Avatar
I never just dump it in. Who knows how much oil is actually in a jug?? I dump 10 in, let it sit overnight and top it up in the am.
Old Nov 14, 2003 | 07:50 PM
Badunit's Avatar
It's pretty easy, but a little messy, to drain just a little if you want to. Unscrew the drain plug, move it a little out of the way, let a little oil drain (over your hand), then put it back in. Just do it cold so you don't get burnt by hot oil.
Old Nov 14, 2003 | 08:18 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Slick trick: I've only heard about this one folks, and from a few others who said it really works.
Only try this after the vehicle has sit for an hour or so.
Take the oil filler cap off,
Fire up the shop-vac and have someone hold the hose (sealing as good as possible) tight to the valve cover.
Remove drain plug.
Break seal at hose/valve cover until "correct" amount has drained.
Re-apply vacuum at valve cover.
Reinstall drain plug.
Props to Illflem on TDR.
Old Nov 14, 2003 | 08:40 PM
bulabula's Avatar
Slick trick? Nice Pun, Shovelhead! I think that method was seen on America's Funniest home videos.
I think Badunits method is the easiest, plus its the perfect time to do it with the oil cold and thick.
Old Nov 15, 2003 | 05:27 AM
spots's Avatar
Hey Shovelhead are you hiding around the corner with the video camera?? I can just see someone trying the shopvac trick and the power goes out at that moment.
Old Nov 15, 2003 | 06:52 PM
Badunit's Avatar
I've heard of the shopvac trick as a way to keep the oil in the pan if you need to take the drain plug out for some reason. Can't really think of many reasons why you'd have to do that, maybe if the plug got cracked or wasn't sealing correclty after an oil change and you wanted to replace it?
Old Nov 16, 2003 | 02:24 PM
SuperGewl's Avatar
Per Cummins, the oil level should be checked on level ground AFTER it is up to temp. You should wait about five minutes after the engine is turned off to get the best and most accurate reading.
My .02 worth
