Oil Level
Old Nov 25, 2007 | 10:32 AM
chrigu's Avatar
Oil Level
hi guys
a have e question about oil level.
i check the oil level on cold engines, the level is on the middle save.(the truck stay a night)
then i start the engines, shut off,wait 10 min the oil level if under minimun.
if this normal?
i have now wait 5 hours an the oil level if in save.but not there hou if on cold engines!
chris
Old Nov 25, 2007 | 10:53 AM
Spooler's Avatar
Yeap, it is normal for it to do that. It takes a while for the oil to drain back to the oil pan. Just make sure the truck is on level ground when checking the oil. Truck will take 12 quarts or 3 gallons of oil. I usually fill up the new oil filter with oil and put the rest down it's neck.
From the way you are describing it you may be a little bit low on oil.
Old Nov 25, 2007 | 11:13 AM
chrigu's Avatar
hi
thanks
the level is on cold engines now just to the letter e from save. e little higher then middle from the save area.
chris
Old Nov 25, 2007 | 12:34 PM
chrigu's Avatar
if this level ok?
Old Nov 25, 2007 | 01:57 PM
Tony T.'s Avatar
Thumbs up
Originally Posted by chrigu
hi
thanks
chris
The area you are referring to is the "safe" point I believe instead of "save". From my owners manual readings this area between "min" and "max" equates to about 2qts. On my 03 CTD 12qts=3 gallons of oil, this usually puts me right at the "max" mark on the oil stick or at times slightly over, I have seen it slightly under the max mark when doing a oil change also. According to the owners manual oil is not to be added until the level is at or below the "min" mark, but some people will add oil even it says 1 quart low roughly mid-way point of the safe area, just to maintain "max" level. Checking the oil should always be done in a relatively level position and I do usually check mine after the truck has set over-night.
Hope this helps some.
Tony
Old Nov 25, 2007 | 10:10 PM
Roperteacher's Avatar
On my 07 5.9 Mine reads on the "Max" line of your diagram most of the time... For whatever reason.... sometimes I ck it and it's between the "E" and MAX on your diagram.. About a half quart... I ck it at the same place all the time... Weird, but thats how it goes...
jmccart
Feb 18, 2008 10:27 AM
jmccart
Dec 21, 2007 06:00 PM
z-rider
Jun 19, 2007 05:15 PM
teckert
Jun 9, 2004 12:34 PM
