Oil level for 10.5 AAM axle w/LS
Old Apr 4, 2005 | 04:58 PM
01350banshee's Avatar
Question Oil level for 10.5 AAM axle w/LS
Planned on changing out the rear pumpkin oil last weekend. Had to put it on hold because I was'nt sure how much to put in it. Looked through the entire owners manual, did not list how much. How many bottles of M1 75W-09 will it take?
Old Apr 4, 2005 | 06:13 PM
HorseHauler's Avatar
not sure on exactly how many quarts but i just always heard till you can feel it to your first knuckle on your finger from the hole
Old Apr 4, 2005 | 08:03 PM
bulabula's Avatar
The DRM says 4.75 pints for the 10.5" AAM. You sure its a 10.5"? I thought those went out with the older 3rd gen SO engine.
If its a 11.5", the book says 7.65 pints.
Old Apr 5, 2005 | 11:48 AM
I may be wrong on that 10.5. I will check my paper work to make sure. Thanks for the info.
Old Apr 5, 2005 | 12:40 PM
dodgedude361's Avatar
You dont have a 10 inch rear. Unless you bought a GASSER?!?
Buy 4 quarts, and start filling. On your last quart bring it up to 1/2 inch of the hole.
Old Apr 5, 2005 | 03:20 PM
bert's Avatar
MY 2004 2500 CUMMINS HAS A 10.5
Old Apr 5, 2005 | 06:35 PM
bulabula's Avatar
I guess 10.5" AAM's come with the automatic 2500's?
Old Apr 5, 2005 | 07:01 PM
eastmentCTD600's Avatar
Guys,
Check the rear end not the paperwork.
All 3/4 and 1-ton trucks equipped with the CTD came from the factory with the AAM 11.5" rear end, if yours doesn't you either swapped it out or you were sold a non-stock truck.
Old Apr 5, 2005 | 08:36 PM
Hannibal's Avatar
My '03 Cummins powered Ram had a 10.5" rear end. The HO 6spd and all 3500's gas or diesel have the 11.5" rear end. My '05 2500 gasser has a 10.5" rear end. All HO Cummins powered Rams should have an 11.5". My '03 got Mobil-1 75w-90. Just under 2.5quarts put it to the full mark. But I thought all '04's were HO's and all had the 11.5" rear end.
dodge35000
13
Oct 15, 2008 08:22 AM
Howling
16
Aug 8, 2008 10:29 AM
24seven
Apr 12, 2008 08:08 AM
joelmopar
26
Nov 20, 2006 11:56 PM
cumminsho2500
Aug 29, 2003 09:56 PM
