Oil drain plug leaks
I replaced my engine oil drain plug in my 05 Cummins a couple of years ago because it seemed to be leaking. I had a lot of oil around the plug and on the bottom of the pan. So I put in a new drain plug. Now after probably two or three oil changes it seems to be doing it again. These plugs have a rubber coating on them that seems to be part of the plug. I'm not sure this is a good design and wonder if anyone else has experienced this and replaced the oil drain plug with one which has a washer seal or something.
Using this on my 05
Or this one...
https://www.genosgarage.com/product/...a/drain-valves
and add this...
https://www.genosgarage.com/product/...1/drain-valves
and add this...
Jeff in TD
08-24-2015 08:09 AM
danc46
03-12-2007 04:10 PM
