Oil Coming Out Exhaust Manifold
Help....i Bought A Truck That Had A Bad Turbo Blowing Oil. Put Good Turbo On And Started Truck. 2006 5.9.. Oil Was Coming Out Of Ehaust Manifold Where It Bolts To Turbo.. Engine Misses A Little Anybody Have Ideas Whats Wrong???
Thanks Stuart |
How much oil? and how long have you ran it since the turbo was replaced? Did you clean the intercooler? You may just have residual oil in the manifold, just not sure about the roughness...
was everything cleaned before it was put back together it could excess. it will run rough cuz of the oil in the cylinders. it took a little bit to clear up when i had a turbo go like that
I Let The Truck Run For Maybe Half Hour Or Litle Longer. I Know The Old Turbo Was Crap And Shaft Broken And Spewing Oil. When Truck Is Running I Can See Some Oil Seapage Coming From Exhaust Manifold And Turbo Housing. How Long Did Your Truck Act Up? The Same Type Of Simptoms?
Thanks |
yea it did but i dint have to much seepage cuz i cleaned everything as good as possible but it took longer then an hour for it to burn stuff off. you need to make sure that anything that got oil in is cleaned completely. i took my intercooler off and rinsed it out several times with solvent to make sure i got it all
