-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   oil changes (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/oil-changes-266402/)
idlewildranch Mar 19, 2010 11:21 AM
oil changes
how often should i change the oil in my truck, i used to change my chevy truck 2500 to 3000 w/5 quarts,now i figure 5-to 6000 w/12 quarts,,what is the best mileage to change the oil.been using mobil one i believe,,its been getting black at 5000 and rotella been new looking at 5000,just thought id ask and see what others are using and doing.thanx
Lost Lake Mar 19, 2010 11:36 AM
This is going to sound like a crazy idea.... You could see what the owner's manual says though.... [dummy]
Some of us have been changing at 3K, some at 5K, I've been 7K to 10K. The oil in mine is like tar because of the in cylinder EGT I guess, but the UOA's are very good so I'm not going to deviate.
If you sleep better changing more often, I say go for it! Use a good filter, I think the Fleetguard LF16035 Stratopore is a good filter. After that, if you use dino oil you should be fine to 10,000 miles (at least I am) and if you use synthetic I suppose you can extend with UOA testing.
Good luck! :)
bansh-eman Mar 19, 2010 11:38 AM
Alot of guys run oil analysis to dertermine that. I run Rotella T and I change my oil every 9k. Black oil is always a probleme because of the EGR stuff. the 5.9L has a "in-cylinder" EGR which is controlled by the timing and cam. It causes the oil to turn black pretty fast. This does not mean the oil needs to be changed though. The TBN is what determines that.
I am about to make the switch to full synthetic oil now that I have added a oil bypass and extend my change intervales out to 18k.
CoastalDav Mar 19, 2010 12:13 PM
I short cycle my oil changes just because of what has been said above with the in cylinder EGR or "Third Event" If you go back and read some of the post that deal with engine rebuilding because of internal problems with rings and scarres in the cylinder walls, suppositly caused by carbon sticking to the rings, you may also want to short cycle the oil change interval.
There are some on the fourm that drive other than CR diesels that don't believe this is problem.
Unless I missed something over the last 10 years with oil classifications, the TBN number, (Total Base Number) was designed to neutralize the acids contained in the exhaust cycle that made it into the crankcase. Left untreated, the sufuric acid from the sulfur in the fuel would eat out the bearings in the crankcase. Since there is very little sulfur in our fuel these days, the TBN should be almost elimanated. CC was the designation for oil that was good at containing Carbon. (Carbon Collecting) We need that now.
I'm sure there are other reasons for carbon on the rings that cause cylinder wear. But since we all know, the crankcase is full of it created by the third event, I don't think I want to run my oil beyond 5000 miles. I have no idea
at what point there is to much carbon in the crankcase. I think this is a problem with the CR Cummins Engine that is known and no one will talk about it especially when you have a warranty problem and they blame it on everything but the third event.
ripping r Mar 19, 2010 12:24 PM
I change once a year or 5,000 miles. what ever i get to first.
tlloyd Mar 19, 2010 01:48 PM
Every 5000miles Delo oil and Baldwin BT 7349 filter. You have to do whatever your comfortable with. Some guy's go 7500 some 10,000 and some even more if they are using syn oil.
GASKICKER Mar 19, 2010 02:34 PM
Ive been going 5k between filter changes and 10k between oil changes with Amsoil.
rufushusky Mar 19, 2010 03:05 PM
I use the same filter with an amsoil bypass with JD dino, 7500 on oil and Baldwin...15000k on the bypass.
pdogg Mar 19, 2010 03:05 PM
10k, oil (delo 400 LE) and filter (stratopore)
sotex Mar 19, 2010 03:35 PM
tbn
tbn on my o4 was 6.63 12500 miles thinking of testing at 15000 on this oil and filter then ?? what tbn nomber is advised to change. this is amsoil 15/40 with 98500 miles on truck. started runing amsoil at 85000. changed filter after oil analyzers test sotex[duhhh][duhhh]
Dr.Dizzle Mar 19, 2010 06:06 PM
I have found that several manufacturers suggest a TBN no lower than 2 as per ASTM(D2896) or 1/3rd of the new oil TBN.
idlewildranch Mar 19, 2010 07:43 PM
so how do i find out what the tbn's are in my oil.i have never even heard of these abbr you guys are throwing out,i usually change about 6000 and everythhing has been ok, i just pump a after market fass fuel system on my truck,will that have anything do do with more carbon or exhaust temps being higher cause of more fuel..is there a test i can buy to check the tbn's in my oil? and where do you guys get the better oil filters,i use fram,but was concidering starting to use wick from napa. i do add 2 strokeoil to my fuel for some lubrisity.
bansh-eman Mar 19, 2010 07:55 PM
I think you may want to search each of the topics your asking about. There was recntly lots of info posted about each of them. Filters being one of the MAJOR issues you need to readup on!
The TBN is something you get when you do an oil analysis. Amsoil uses a place that includes it with your analysis, where Blackstone charges extra for it.
CoastalDav Mar 19, 2010 08:04 PM
Just for my edification, what does tbn mean with regards to oil analysis?
As stated above, my interpetation was as it applied to an additive in the oil.
After I read a few more posts, I figured you guys were talking about something else [duhhh]
sotex Mar 19, 2010 09:08 PM
total base number . having yer oil analyzed lets you know wat type of weare antear going on in ther. and when oil neds to be changed
