-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Normal trans temp w/sensor in pan (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/normal-trans-temp-w-sensor-pan-80974/)
BlackJeep Oct 20, 2005 08:48 PM
I recently installed ISSPRO gauges in my '05 (pics in my gallery). I mounted the trans temp gauge in the pan using the drain plug kit. After fully warming up (30+ minutes driving w/no load) it levels off at about 130 degrees. The local air temps have been in the 60's this week. Could this be reading wrong? Is it possible that it really stays that cool?
I was surprised that the sensor didn't stick into the pan very far. When tightened all the way into the drain plug, the end of the sensor was about flush with the back of the nut inside the pan. Is this normal?
Thanks to all for your help, this site is a great resource!
BlackJeep
Tfeore Oct 20, 2005 08:52 PM
Mine sits between 140 in the morning and 180 during the day. Rush hour traffic.
tom
PS Welcome to the club...
Edit: I'm plumbed into a deep ATS pan.
abbeyinc Oct 20, 2005 08:54 PM
mine runs 150-180 with the outside temp around 45. I am plumbed into the output fluid lline to the cooler.
Check out the posting at DTT's site:
http://www.dieseltrans.com/phpBB/viewtopic.php?t=558
Dodgezilla Oct 20, 2005 09:04 PM
Mine's the same as Tfeore although I just have the stock pan.
BlackJeep Oct 20, 2005 09:11 PM
So, maybe my sensor is bad? It sounds like 130 is much too low...
BlackJeep
Tfeore Oct 20, 2005 09:28 PM
It's lower than some but your ambient is easily 20* lower than mine. We were in the mid to high 80's today. I run 180 in the summer all day long.
tom
Dodgezilla Oct 20, 2005 09:48 PM
I say it's probably close to normal. I had a guage in my 98 auto CTD and usually the needle didn't even come off the peg. I thought it was broken until I hooked my trailer up and then the needle moved.
TAS05CTD610 Oct 21, 2005 10:15 AM
Temp
Comming to work I think I saw 100 degrees in the tranny output line. It was only 40 degree's out and work is only 15 miles so yeah, depends, and if you tow you'll see it more more than when empty
