Normal trans temp w/sensor in pan
I recently installed ISSPRO gauges in my '05 (pics in my gallery). I mounted the trans temp gauge in the pan using the drain plug kit. After fully warming up (30+ minutes driving w/no load) it levels off at about 130 degrees. The local air temps have been in the 60's this week. Could this be reading wrong? Is it possible that it really stays that cool?
I was surprised that the sensor didn't stick into the pan very far. When tightened all the way into the drain plug, the end of the sensor was about flush with the back of the nut inside the pan. Is this normal?
Thanks to all for your help, this site is a great resource!
BlackJeep
BlackJeep
mine runs 150-180 with the outside temp around 45. I am plumbed into the output fluid lline to the cooler.
Check out the posting at DTT's site:
http://www.dieseltrans.com/phpBB/viewtopic.php?t=558
I say it's probably close to normal. I had a guage in my 98 auto CTD and usually the needle didn't even come off the peg. I thought it was broken until I hooked my trailer up and then the needle moved.
Temp
Comming to work I think I saw 100 degrees in the tranny output line. It was only 40 degree's out and work is only 15 miles so yeah, depends, and if you tow you'll see it more more than when empty
Igor
May 8, 2006 11:48 PM
betsycam
19
Aug 19, 2004 08:30 AM
RamRat
Apr 3, 2004 12:53 PM
