No 4th gear and code p1740
I was on freeway pulling an empty trailer and hose of transmission cooler come off so when transmission started popping out off gear I pulled over but by that time I lost my oil
So I hooked the hose filed it with oil and drove it home , replaced filter and oil three times and adjusted bands there was a lot black stuff in the oil pan , it was shifting ok for two days now transmission wont shift in 4th gear at light throttle between 1-2 gear it shifts weird...feels like popping out of gear and then it catches if i floor it every thing is fine Any suggestions? |
sounds like overdrive is smoked. you can bandaide it by doing an overdrive overhaul (new clutches) but that is and will be only temporary.
