New ball joints and tires, now squirrley
Doing what? Incorrectly diagnosing parts? Ignoring the original problem and replacing everything else that may or may not be bad?
Unfortunately the only way I found to really check the ball joints was to have the wheel off, disconnect the tie rod end and move the knuckle back and forth by hand. Then you could feel the stick/release, if you have good joints it will move smoothly through it's whole range of travel. It's rather like a bad u-joint, where it will have a very free spot in the center of it's range of motion.
Really?? Where the h e double hockey sticks did I say to replace said parts!?? I simply gave the OP some sugggestions as to what parts to check that may be the cause of his issue... I pointed to suspect parts and what to check for... holee crap batman ... you need glasses or re-read the posts!
firebill1720
20
03-05-2010 09:23 AM
sakisaki400
23
12-31-2006 10:17 PM
njmaier
15
07-26-2006 07:43 AM
Seeder
02-15-2006 08:15 PM
