New 6.7- 350hp and 650tq
#123
You have figure that in 2008 you will be able to get the Aisin tranny with all the CTD's if you are willing to pay for it. I think most people on this site will wait till 2008 to buy one. We all get a good laugh at Ford guys who ran out and bought the H/O 6.0 in 03. I am chuckling right now as I wrote that. So give it time. Let them fix the bugs and Performance places perfect the programers. And then start shopping for an 08 with the Aisin
I guess if your suggesting that they would offer the Aisin as an option to the 68RFE, I also highly doubt that. There would be no great reason to do so.
#124
I have to disagree on that. Every gear that power from one point to another point robs power and creates friction. A 1:1 output is the most efficient way to get engine power to a driveline and then to the rear differential. A small gain, but a gain that works towards better fuel economy than against it.
I think that people have just been brainwashed with the buzz word "overdrive" equaling fuel economy.
#125
#126
You may be right, but if you make a few changes in the direction of fuel economy it makes a big change.
#127
#128
My Titan was setup like you described. The ring and pinion had a 3.36:1 gearset, and that was their towing gearset. Non-tow package trucks had a 2.94:1 ring and pinion. Both pretty high when compared to the domestics. The 5-speed auto transmission, on the other hand, was geared lower than the Big 3's trannies. Final drive ratio was virtually the same as the Big 3's. It seemed to work really well, but I don't know how it affected fuel economy.
#129
Why could'nt they make the transmission have lower gears 1-5 with a 1:1 final in 6th and run a say 2.92:1 or 3.23:1 rear end for mileage? Then have the transmission use only 2 - 6 in auto non tow mode and 1 - 6 in tow mode.
Then for the daily driver it would start off in 2nd (which would be close tol the current 4 speeds 1st gear ratio-maybe a little lower) and if you hooked up to the trailer you just drop it into tow mode for the additional lower first gear take off power.
Ohh ohh....might of ran into a snag. Wouldn't this then mean that you either have more disproportinate sizing of all the driving/driven gears in the tranny?
Well, either way, I still like the idea of taking off in different gears, based on the load.
#130
Exactly. It's a tradeoff. And like my aforementioned Titan, early models had problems with differentials grenading. Some claimed it was because the pumpkin was too small for sufficient cooling.
#131
hahahah....THis was a good thread, turns out the rumor mill was right again!!! There is a dodge 6spd auto and an asian!!!! I love DTR and its members!!!
Luke S
60
04-02-2007 10:47 PM
dodgeguy71
04-30-2006 09:29 AM
Tiara3100
21
03-08-2006 08:17 AM
