need help 07 5.9 running hot
Old Jul 2, 2008 | 11:15 AM
sallyman1's Avatar
ive seen 210 -125 pulling my 10000lb camper up hill and about 205 on flats. (190 unloaded) I see 1300-1500 egt climbing hill, 1250 on flat pulling.
my egt not pulling on flat is about 800
Old Jul 2, 2008 | 12:28 PM
DBLR's Avatar
One thing to remember is that your temp gauge only shows what the computer thinks it should read, so what it shows is not an acute temp reading.
Old Jul 2, 2008 | 12:35 PM
snoyes's Avatar
I saw about 205 pulling about 10K through the Yukon. Temp outside was in the 50-60s, I think your truck temps are normal.
Old Jul 2, 2008 | 11:00 PM
sallyman1's Avatar
so when i see 215 for a temp going up hill it could be 240? Because of my edge?
Old Jul 3, 2008 | 11:39 AM
1100hp's Avatar
good ? now is there any good cooling mods.. alumuimin rad. better pump lower thermastat.. what works guys..
Old Jul 3, 2008 | 04:51 PM
MoparNut's Avatar
I believe the factory rad IS aluminum.
I don't think you have anything to worry about. Factory gauges have been known to be off by a small %.
Last summer pulling in 97* temps on flat road 70 mph, a/c on and 8k car hauler, my temp was 205-210.
If I hammer the pedal just playin around the gauge will go to 205-210 for about 15 seconds and then drop to 190.
I think your truck is normal.
Old Jul 3, 2008 | 09:44 PM
NickBeek's Avatar
Those temps are completely normal for these trucks. Mine has done the same thing since day one, and is stock. The temp gauges on your ford and my old fords never moved because they were glorified idiot lights. The computer generated their output. Our oil pressure gauge is that way on these trucks, but I believe the temp gauge is actually pretty close to real. The only concern I would have is running EGT's at 1400 for more than a few seconds. I don't ever tow with added power.
whosdunit
Feb 16, 2019 04:07 PM
Doj Dewd
Sep 10, 2010 10:50 AM
Strjock81
16
Dec 12, 2007 09:53 AM
edwinsmith
Apr 14, 2006 03:53 PM
duallydave
Aug 7, 2005 09:38 PM
