Mpg report towing & empty
Left the RV in Alberta at the BILs and came home empty.
To first fill:
221 Km (136.41 miles) used 23.5 L (6.21 US gal) diesel fuel = 21.96 US mpg
For the metricans:
221 Km/23.5L = 10.59L/100Km
Second fill:
469 Km (289.5 miles) used 50.2 L (13.28 US gal) diesel fuel = 21.79 US mpg
Conditions/settings:
- 2007 (5.9L Cummins) Dodge Megacab 4x4, 3.73 gears, auto trans
- Relatively flat terrain
- Temp mid 80s, not much wind that day
- Ran A/C the whole way
- Cruise set at 106 km/h (65 mph)
- Cargo bed full of junk/camping gear/bikes
- No topper/tonneau cover
- Stock sized tires
- No lift
- OE Tires at 80 psi rear, 60 psi front
- Hypertech on stage 2, truck all stock otherwise
Towing mpg was as high as 11.6 mpg, and as low as 10.0 mpg. The 11.6 was no A/C and no wind, and the 10.0 was over mountainous terrain with a 90 Km/h (55 mph speed limit). RV is a 36' 5th wheel weighing in at about 11,500# - GCW was about 20,500#.
I'm pretty happy with the numbers and had to brag!
To first fill:
For the metricans:
Second fill:
- Stock sized tires
- No lift
That is just about what I got a month ago on a trip from SF Bay Area to Missoula, MT and back. Best tank for the trip was 22.3 MPG, and worst was 20.9 (hand calculated of course). Nice to only have to fill once going each direction.
Numbers are all hand calculated. Distance driven divided by fuel used.
I should point out that this is about the best mpg I have got with this truck. It will do 20 easily (which is the norm) but almost 22 was something I had to brag about.
To first fill:
For the metricans:
Second fill:
To first fill:
For the metricans:
Second fill:
221km = 137.3 miles
23.5l = 6.208 gallons
22.11MPG
469km = 291.4 miles
50.2l = 13.26 gallons
21.97MPG
banana
Feb 17, 2010 03:32 PM
stock03
Oct 4, 2006 10:19 PM
estesbubba
Jul 6, 2006 09:23 AM
pcm
