-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   miss-fire or back-fire? (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/miss-fire-back-fire-70477/)
pianotom Jun 14, 2005 10:32 PM
I have a 04 600HO engine that misses or backfires every once in a while, usually after a fill-up.
I have used fule from differant sources. Chevron, Shell, Safeway, or Terxaco etc. The truck has 17K is automatic, if that means anything.
Are there great differances in the fuel? I am not the mechanic type and could assume things all day. Any suggesions from anyone? Any clues would be helpful. Thanks....Tom
Hounddog Jun 14, 2005 11:55 PM
Make sure filter is ok(replaced at 15k) then take in in if still doing it.Possable injector bad.
bigblock2stroke Jun 15, 2005 03:34 PM
backfires? I usually associate that with a loud shotgun like bang. If that's the case, take it in.
If it just misfires with smoke and a little noise, you still need to take it in and document it if anything. Probably injectors, but you may need a reflash depending on your build date (on engine vanity cover sticker). Maybe both.
