Mag hytec
Old Dec 26, 2007 | 06:15 PM
bluechrome's Avatar
Talking Mag hytec
Well just got by rear cover and wanted to know which oil I should use. I have 3.73 Limited slip rear end
Thanx
Chris
Old Dec 26, 2007 | 06:41 PM
dodgezilla04's Avatar
i use redline. 8 quarts now. ouch.
Old Dec 26, 2007 | 09:21 PM
bluechrome's Avatar
Redline? What type/viscosity
Old Dec 27, 2007 | 01:35 AM
TexasCTD's Avatar
Any 75w90 GL-5 rated synthetic gear oil is fine. I use Mobil 1 with great results.........available at the local GhettoZone.
Old Dec 27, 2007 | 12:01 PM
snoyes's Avatar
I've used Amsoil 75w90. Any GL-5 syn is fine. Took about 7.5 to fill er up with the Mag Hytec. Watch the torque on those bolts putting them on, very important not to overtighten them.
Old Dec 27, 2007 | 03:03 PM
bluechrome's Avatar
Question
I need 7.5 quarts correct?
Old Dec 27, 2007 | 04:47 PM
haulin-rv's Avatar
I have had good luck with Amsoil, tried Royal Purple and was not impressed at all.
Old Jan 1, 2008 | 11:51 AM
bluechrome's Avatar
What is the gl-5 rating mean. My father in law is a oil distributer and says he has Mobil Delvac1 75W90 Full synthetic Gear oil. BUt I can't find the gl-5 rating any wear on the bucket. Is this stuff okay?? He uses it in all his big trucks.
Old Jan 1, 2008 | 02:06 PM
rogers259's Avatar
Why not RP? I have 8 quarts of 85-140 sitting in the garage waiting to be put in, I'd like to know if you have actual facts other than not impressed.
Old Jan 1, 2008 | 06:29 PM
Dieselhed's Avatar
I have used Royal Purple since I first changed both diffs. No problems for me. I don't know how an oil can impress you anyway. It's #$%&@*# oil. It comes from the ground.
Old Jan 1, 2008 | 06:46 PM
rogers259's Avatar
Kinda my thoughts as well
Old Jan 1, 2008 | 08:03 PM
D-Roc's Avatar
Only time I have seen oil impress me is when it's -30 and I'm using synthetic.
15W40 sure doesn't impress at those temps
Old Jan 1, 2008 | 11:41 PM
TexasCTD's Avatar
Here is some reading I came across just doing a quick search. http://www.lubrizol.com/products/aut...ar-oil/GL5.asp
http://www.mobil.com/USA-English/Lub...scriptionTitle
If you look closely you will see the Mobil Delvac Syn it is also GL-5 rated.
I don't know if there is a difference......between Mobil 1 and Mobil Delvac or not. I use this....bought at Autozone---> http://www.mobil1.com/USA-English/Mo..._75W-90LS.aspx
Hope that helps.
Old Jan 2, 2008 | 07:23 AM
PoorMansCat's Avatar
Running 75W140 Valvoline Synthetic in my Mag Hytec. Took EXACTLY 8 quarts to fill it up. RP and AMSOIL are not readily available around here. Not really interested in ordering lube when I need it, like the idea of just going to the local Napa and buying it.
When it warms up and I get done with my in-laws PowerChoke, I'm gonna install my front Mag Hytec.
LinearX
May 11, 2004 02:34 PM
Commatoze
Aug 18, 2003 08:54 AM
Commatoze
Apr 2, 2003 12:53 PM
Paradise Racing
Mar 12, 2003 09:53 PM
