low sulfur or ultra low sulfur?
Hi, I just got a new 07-5.9 and was wondering which fuel would be better for the 5.9 In my town I can get either. The pump with low sulfur diesel says not for 07 or later but I don't think it means the 5.9. It doesn't say to use ultra low in the manual.
Wow, I thought all fuel stations had to switch to USLD by some time last year. From what I understand LSD has better lubricity. I dont think there would be any advantage to use USLD, but I could be wrong.
The LSD is better, no doubt. Good for the truck,bad for the enviroment. If your 07 has a diesel particulate filter (new emission standards), you can only run ULSD. it will clog with LSD.
I know around here and in a lot of other areas that even though it says "LOW SULFUR DIESEL" that it is really the ultra low. It depends on the area that you live in. They arent required to say if it is ultra low but they might be required to carry only ultra low. Check it out
Are you talking about the DIESEL PARTICULATE FILTER on the exhaust??? A 5.9 no matter what year it is does not have any kind of particulate filter on the exhaust. Or at least i havent ever heard of one nor has it ever been mentioned at any of my training classes. A 5.9 L should only have a CAT, MUFFLER, and on the newer models most have a resonator.
I miss the thicker smoke the LSD gave my stock truck.
Dieselnick is right. The truck has to be manufactured after 1/1/07. My truck is an 07 model year but was manufactured in 2006 and has the 5.9. So I'm able to run LSD if I can find it. The LSD would give me about 1 more mpg than the ULSD. I wish I could find more of it now!
When I got my truck in Feb 07 I specifically searched out a 5.9 so that I could stay away from the DPF and so that I could run LSD if available. I also went for the 5.9 because there is and probably always will be a lot more performance parts available.
Also, the 07 5.9's come with a card in the owners manual explaining that it is ok to run LSD in them.
