kinda in a jam
po193 can i bypass this in any way????????? that is the only code it is showing pickup is hard to start and cuts out a little
p0193 -fuel rail pressure sensor circuit high input !
Check all the connections at the rail pressure sensor. If you have a performance box on it, that is most likely the culprit. Double check the connections, and if all else fails try removing the box.
i unhooked my quad tow chip and pulled the sensor and cleaned it sems like everthing is back to normal can quadillza do something with the box thanks for the help
Usually it's just a bad connection at the sensor. Might try hooking it bak up now and see how it is.
thanks dude nice handle and merry x-mas
You too! Good luck!
