Just bought an 03 3500 - have a question
I just picked up a 2003 4x4 HO 6spd 3500 SRW truck.
I noticed that the front U-joints have some play in them, and that the prop shaft has had the U-Joint at the tranny replaced already. Are these U-joints covered under warranty? Do they typically wear out - or did the previous owner just use 4x4 on dry pavement alot?? I think my first mod will be a set of bigger tires - the 4.10's are Killing me! [laugh] |
No, the U-joints are not covered under warranty. Yes the stock U-joints fail. I had 2 of th 3 on my rear driveshaft fail.
Bill |
I haven't had any problems with mine but I did have to get the transfer case seal replaced under warranty. The big tires will make the truck look much better..:D
Congrats on the purchase...... |
thanks Dodgezilla, I'm looking at some BFG 315-70-17's.
I should have clarified....The front outter U joints at the wheel hubs are the ones with the play in them. The rear prop shaft coming out of the transfer case has had it's U-joint replaced already. |
