Its prolly a long shot but need help!!!!!!
Ok ladies and gentlemen, i got a 03 3/4 ton with an automatic and it was in a front end collision. got it outta the shop and it wont shift at 60-65ish... its pushin 3 grand and wont grab the next gear... wen i shift it from park it wont even show the circle around the "D" on the prnd12 display. i also have to give it quite a bit of throttle to get er rollin..... any help would be greatly appreciated.
Sounds like the linkage needs to be adjusted. It's behind the plastic cover just under the steering column, a little square black box with a white clip on it. Pull the white clip off and there are a bunch of grooves to make the adjustment. I would probably check the TV cable and adjustment also.
But that dont seem like it would b the reason behind me havin to give her so much throttle b4 i actually start rollin tho... i meen wen im rollin 65 im hittin 3 grand on the tach, and that aint healthy lol
Tyler_02
08-18-2011 01:40 PM
Jeeptug
04-24-2007 08:22 AM
Buffman88
12-21-2006 06:32 PM
