Installed Guages...Trans Temp Question
Old Jan 22, 2008 | 09:21 AM
Tiara3100's Avatar
Question Installed Guages...Trans Temp Question
I installed a set of ISSPRO guages in my truck over the weekend and Notice the transmission temp was higher then I expected. I installed the sender in the "Hot Line" going from the transmission to the cooler on the block. While sitting in the drive thru I saw my temp guage go to 195+, even though it was 30* outside. I can only imagine what the temps will be in the summer when I tow my 9,000lb trailer when it's 100+ degrees out.
What temps are normal and safe?
(Remember-Sender is in the "Hot Line")
Old Jan 22, 2008 | 09:22 AM
1-2-3's Avatar
Just a plain ole guy
You'll see them drop. There's alot of friction going on when sitting still. It'll drop just as you take off driving.
Old Jan 22, 2008 | 10:58 AM
coparam4x4's Avatar
Yea that's pretty normal. When you get back on the road and your TC locks up then you will see temps drop. I've had mine up to 240* breifly while climbing a steep hill with my 11k toyhauler, other than that it is usually in the 150-195 range, towing. Mine usually hangs around 195* in stop n go traffic here in Phx with outside temps in the 110's. This time of year mine doesn't seem to get above 130* on the highway.
Old Jan 22, 2008 | 11:03 AM
rogers259's Avatar
I dont think i've seen mine above 130* lately, but I have mine installed in my mag-hytec trans pan, so I'll probably see lower numbers than yours. Like it was mentioned above just sitting around it will climb.
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
IntakeRacing
Jun 9, 2007 08:13 PM
Dr. Evil
19
Oct 12, 2005 12:16 PM
Lrdchaos
Jun 30, 2005 07:23 PM
