Installed the Dynatrac Prosteer Ball Joints
Old Jul 28, 2011 | 06:26 PM
lniemeyer2's Avatar
So far so good! I don't have to fight the truck on the to lane black tops any more and steering is tight again. Hopefully my tire wear problem will be solved also. It was starting to wear the tires really wierd almost like cupping but diffierent so I figured it was ball joint time at 120K. The drivers side was a little loose but not bad and the passenger side was really bad, so loose it looked like it was about to fall out. Weird thing is the prybar under the tire trick showed the drivers side with about 1/4 slop and the passenger side with less than that, go figure the one that check out the best was in the worse shape!
Old Jul 28, 2011 | 10:51 PM
06RAM2500's Avatar
They greasable??
Old Jul 28, 2011 | 11:04 PM
OOPS's Avatar
Originally Posted by 06RAM2500
They greasable??
Yep and rebuildable.
Old Jul 28, 2011 | 11:32 PM
annabelle's Avatar
How was the install? I have a set waiting on my bench!
Old Jul 29, 2011 | 09:17 AM
OOPS's Avatar
Mine went very easy, once I made the right adapters for my Harbor Freight ball joint press.
Old Jul 29, 2011 | 05:36 PM
lniemeyer2's Avatar
They install just like any other press in ball joint. I got my set from 8 lug truck gear and got the adapter kit with them for $10. Basically its a washer/shim and another cup for your press that is built specifically for the dynatracs. If it is your first install be prepared for about 8 hours a side it can be a bear to get the wheel bearing out and I have broke cheap presses getting the ball joints out. This was my 3rd set I have installed, first ones for myself but it took me about 8 hours to do both sides. There are some really good write ups on here with pics to go by if you need help that lay it all out pretty well.
Old Aug 3, 2011 | 05:40 PM
Almond Pale Ale's Avatar
I've had mine in since April, one of the best things I've done to the truck.
zachv
Jun 19, 2014 12:39 PM
CoeGuthrie
Nov 7, 2011 07:31 PM
89dieselkong
Jan 4, 2011 07:26 AM
Mindy
Jan 23, 2010 09:43 AM
bradler
15
Jan 2, 2010 08:34 PM
