injector longevity
Old Jul 8, 2009 | 04:03 PM
steelblitzkrieg's Avatar
DTR Detective
See post #3 in this thread...it was actually 42,XXX miles.
#3 injector failed again 43,310 miles.
2 tanks of Fuel between failures.
Old Jul 8, 2009 | 06:17 PM
t-boe's Avatar
Got you all beat. I've had 8 injectors go in 23,000 miles. None due to filtration problems just faulty injectors.
Old Jul 8, 2009 | 08:46 PM
DTR Detective
Really? Holy expletive! That's a bad run of injectors.
Do you change the oil after 500 miles with each injector replacement?
(They change the oil due to fuel in it, then 500 miles later they make me pay for it to be changed...Make = Recommend so warranty doesn't have to cover it, but protects them if something goes awry)
Old Jul 8, 2009 | 09:43 PM
banyon's Avatar
The teck told me mine were shorted out not stopped up. I agree that a better filter is a good idea but that`s not what was wrong with mine.
Old Jul 8, 2009 | 10:29 PM
chadder1313's Avatar
Whats the build date on your engine?
Old Jul 8, 2009 | 10:39 PM
RiverRat2's Avatar
125,000 still on the stocker's.. Been using Wix filters since day one. Been running the Juice on level 5 for over 50,000 miles. No problems yet.
What Micron is the Wix??? That is whats been run in my truck 73K,,, no problems,,,,,,YET!!!!!! LOLOL!!!!
Old Jul 8, 2009 | 11:03 PM
t-boe's Avatar
They weren't straight streaming and filling the crank case, just causing the white smoke and rough idle issues.
Old Jul 9, 2009 | 07:36 AM
cincydiesel's Avatar
10 micron.. I changed to Fleetguards at 110,000 miles because they were easier to get for me. I liked the Wix filters..
Cincy now currently putting on flame suit
Old Sep 28, 2009 | 01:29 PM
hemi_on's Avatar
Smile
I've got 323900 km and over 8000 hours on the stockers, with zero motifications to the fuel system
Old Sep 28, 2009 | 01:41 PM
Don M's Avatar
DTR Advertiser
Avoiding water is the key. Water kills these things. I have seen a tank of watery fuel kill all 6 injectors in under 50 miles!!
The resin in the filter media is what removes the water from the fuel, but if the fuel is traveling too fast through the media, the effectiveness is less.
Of course low micron filtration is good as well, but secondary from what I see here.
Old Sep 28, 2009 | 03:35 PM
dieselfreak21's Avatar
Shouldn't the senor tell us of this problem? Don't doubt you one bit or did dodge or cummins not do thier homework again and not put in a sensor that is sensitive enough to see it before it causes problems? I also hear a good lubricating aditive will help as well.
Old Sep 28, 2009 | 07:10 PM
Bullit's Avatar
5 injectors in 33,000 miles. 2007 2500, 2 years old. the #5 went two different times. i had one go at 10,000 miles.
Old Sep 28, 2009 | 07:53 PM
justin mcfall's Avatar
80,000 on stock sticks.. Baldwin 5micron smarty on SW-3. I change fuel filter every oil change,5,000 miles..
m1a convert
Mar 12, 2011 06:49 PM
Thrust
Nov 14, 2004 10:31 AM
supercharger
Mar 22, 2004 09:34 AM
sdgunslinger
Apr 5, 2003 07:42 PM
jlells01
Feb 1, 2003 03:57 AM
