injector longevity
Old Jul 1, 2009 | 10:03 AM
dieselfumes57's Avatar
injector longevity
I was told injectors are only good for 120 to 140k in my 06. Does anybody have any input on this? I was hoping to get around 200k.
Old Jul 1, 2009 | 01:15 PM
TexasCTD's Avatar
The key is fuel filtration and the stock filter generally is not good enough.
Alot of guys on here run an extra 2 micron filter after the stock fuel filter and before the fuel goes to the CP3 injection pump.
With proper fuel filtration, you can prob go 200K or longer. Every truck is different and run under different sets of circumstances and sources of fuel. But you can improve your odds alot by filtering that fuel as clean as possible.
Old Jul 1, 2009 | 04:15 PM
steelblitzkrieg's Avatar
DTR Detective
#3 failed at 40K
Old Jul 1, 2009 | 05:43 PM
JP-4.5's Avatar
124k on my stocks... 2micron went on around 20k on truck..
Old Jul 1, 2009 | 05:57 PM
Roperteacher's Avatar
#5 went at 17,000 on mine. 2 micron added immediatly and so far so good!
Old Jul 1, 2009 | 07:17 PM
hivoltage's Avatar
Is the Baldwin 5 micron not good enough?...
Old Jul 1, 2009 | 09:42 PM
MikeyB's Avatar
It's better than the Fleetguard 7 micron!
MikeyB
Old Jul 1, 2009 | 11:09 PM
FMB's Avatar
FMB
Injector #1 failed closed at about 97,500 miles. It's replacement and the other 5 originals seem to be doing fine at 171k miles. I have a couple trips coming up so when I get back mid August or so, I hope to be sending all 6 to DonM for testing and 1.6 tips. I tow about 9,500# 10% of the time and like power and milage (do those words even go together?).
I combine Fleetguard filters and quality fuel.
Old Jul 2, 2009 | 12:09 AM
I think Mine are ok for now at 137k. But i have ran a bd on performance since 150 miles. I have noticed now that i am covering everybody up behind me with black smoke alot more than usual.
Old Jul 2, 2009 | 07:54 AM
hivoltage's Avatar
Whats the cheapest route for putting in a 2 micron between canister and CP3?...Times are tough right now so cheap is good...
Old Jul 2, 2009 | 08:33 AM
trik396's Avatar
Do a search here for a CAT 1r-0749 or CAT 1r-0750 filter setup. I don't think I have $100 total in mine originally... Then I added another (dual filters) because I believe in overkill. Still cheaper than the kits you can buy.
Old Jul 3, 2009 | 11:29 AM
banyon's Avatar
Mine in my 06 went out at 88,000. I`m watching my Duramax. It`s the same year, same fuel only a different driver. It has about 50,000 miles on it. When the early Duramax had alot of injector problems GM extented the warranty to 200,000 miles. My truck has been at the dealer waiting on injectors for over a week with no end in sight. Doesn`t Dodge think this will influence people like me when I get ready to buy a new truck?
Old Jul 3, 2009 | 12:22 PM
banyon's Avatar
The dealer just called & said my truck was ready. One week instead of two. I`ll be glad to get back behind the wheel.
Old Jul 8, 2009 | 12:11 PM
sCreamin400's Avatar
I plugged one at 50k and another one Monday at 75k. Have an appt. Monday at the dealer to get them looked at. Would like all new updated ones that I can send out to get worked over a bit.
Old Jul 8, 2009 | 12:23 PM
cincydiesel's Avatar
125,000 still on the stocker's.. Been using Wix filters since day one. Been running the Juice on level 5 for over 50,000 miles. No problems yet.
