Injector Cleaners
Old Nov 29, 2009 | 10:34 AM
rammer123's Avatar
Injector Cleaners
Do you guy's use fuel injector cleaners or additives to your fuel.
Old Nov 29, 2009 | 01:43 PM
DirtEater's Avatar
Yes we do.
Old Nov 29, 2009 | 02:14 PM
bigjohn04's Avatar
I use Power Service's Diesel Kleen + Cetane Boost every couple of fill ups.
Old Nov 29, 2009 | 03:31 PM
rammer123's Avatar
so I can use any type of diesel additve from Pep Boys, Auto Zone
Old Nov 29, 2009 | 03:44 PM
rockcrawler304's Avatar
Yes. If it is made for diesel you will be fine. Power Service is what I also use and is a very common one.
There are several that are made by companies that specialize in gas vehicles and have one product for a diesel. I would try to stay away from those but that is just my 2 cents.
Old Nov 29, 2009 | 03:47 PM
DirtEater's Avatar
You can get jugs of Power Service Diesel Kleen either in the gray or white bottle at Walmart. I'd recommend the white bottle this time of year. Pep Boys and Autozone carry it, but it will not be as cheap.
Old Nov 29, 2009 | 07:14 PM
Spooler's Avatar
No, I don't. No need for it. Just work the truck from time to time.
Old Nov 29, 2009 | 07:25 PM
akrammit's Avatar
Always, every fill up. I use powerservice because that is what's easily available up here. I really like stanadyne but can't get it up here. I use the winter anti gel kind in the white bottle during winter and the grey bottle in the summer.
Old Nov 30, 2009 | 08:46 AM
billie's Avatar
^^Same here.
Old Nov 30, 2009 | 01:35 PM
DirtEater's Avatar
billie, You don't use an anti-gel additive in Calgary?
Old Nov 30, 2009 | 01:46 PM
DBLR's Avatar
I like Lucas as it does not contain solvents like many other cleaners do.
Old Nov 30, 2009 | 07:08 PM
Spooler's Avatar
I used to use it..... I have used PowerService (makes some serious timing rattle in the cold weather), Howe's meaner cleaner, etc. Truck was still noisey. One day I just hooked up to my trailer to get hay..... After I was done,,,,,hunh, no more noise. Don M. has stated many times he very rarely see's issues with the injectors due to lubrication. It's mostly water or over pressure problems. Do what you like, just wasting your money in my opinion.
Oh yeah, take all that money you spend on the additive and put it into a good 2-3 micron filtration system. You could have it quick for what you put into running all that junk.
Old Nov 30, 2009 | 08:17 PM
bansh-eman's Avatar
I normally run 12 oz of PS every other fillup
Old Nov 30, 2009 | 08:34 PM
HOHN's Avatar
Lubricity problems are far more likely to show up in the CP3 than in the injectors.
For injectors, deposits are the problem.
Old Nov 30, 2009 | 09:39 PM
billie's Avatar
No need, our winter fuel is blended so it won't gel in Canada, at least I've never seen it and I've run to -39*C (about the same in *F).
