Idle Problem On 2005 - Dodge Diesel - Diesel Truck Resource Forums
Old 02-27-2018, 02:41 AM
I have a 2005 Dodge 5.9L Cummins. It idles at the normal 800rpm but when I put it into drive with my foot on the break the idle goes up. If I take my foot off the break it lunges forward and seems that the rpm is about 1200 to 1500. I replaced the fuel control actuator and the pressure sensor and it fixed the problem for about two months but now the same problem is back. I have also changed the fuel filter. Can anyone help?
dridge is offline
Old 03-08-2018, 06:52 PM
Did you ever figure out what was the problem? I am having the same issue.
1jarhead is offline
Old 03-09-2018, 10:27 AM
FMB
To me, it sounds like you have an issue with your Torque Converter. Someone on here that knows transmissions should be able to help you, but if you get no help, it probably needs to go to a transmission shop. To me, an automatic transmission works on the FM principal so I can't be of any more help.
Back to morning brew . . .
FMB is offline
Old 03-09-2018, 10:43 AM
thank you, I thought it was tranny related because I have no codes so it must be something mechanical I think.
1jarhead is offline
DADDY'S DIESEL
12-04-2018 10:08 AM
freds89
05-07-2009 09:54 PM
BCarmicle
09-14-2005 08:27 PM
shortround
06-25-2005 11:28 AM
shortround
02-05-2005 09:40 AM
Quick Reply: Idle Problem On 2005
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
