Idle noise
Idle noise
Now before you guys start making jokes at this i'll tell you that im a diesel mechanic. I noticed for the first time today that my truck started making a terriable ticking or knok. It has never sounded like this before at a idle. The mileage is just about at 30,000 and I just wanted to know if anyone else is hearing the same noise.
Does it do this at idle under a load? Or under no load?
It could be the clutch plate rattle, for which there is a TSB.
Could be a stuck injector, too. California trucks can detect a stuck pintle, but regular trucks cannot.
Re: Idle noise
BTW, Cotsco has great deals on USB cables (noted from your sig).
Originally posted by Haulin_in_Dixie
Try loosening the injector nuts one at a time to locate which one it is. Then you could try switching the injectors to see if it is an injector.
Bill
DANGER
) Never run your engine or be close to the system with a loosened nut because of constant extreme high pressure
Instead try disconnecting one injector control harness at a time and that could narrow it to 2 cylinders.
Also check how fast the tick is. If there's about 6 ticks per second at idle it's injection related most likely, if it's 12 times per second then it could be a reversed piston but not likely.
I would try fuel from a different place and/or good fuel additive. Some who have had a knock got rid of it with additive.
Vaughn
Originally posted by spots
Haulin I laughed when I read the last line of your sig. Not funny for you with the engine but that you have a sense of humor about it. Thought about buying a '03??
Seriously, I usually keep a truck 10 to 15 years, got a while on this one yet. I like the truck. Except for the engine problems now, I had it just about where I wanted it with power, handling. Jeez, it even has a new heater core
With all the repairs miles and upgrades, it still rides smooth, tight cab, fast and comfortable, still get complements on how it looks. When it starts feeling bomby than I will consider a new one.
