identification label
Old Nov 9, 2006 | 08:38 PM
iaddiesel's Avatar
I am looking at trading in my 95 ctd for a 2006 2500 QC long bed. Where is the label that says what tranny, and what rear end/front end and axle ratios this thing has ?? I looked in the glove box, under the hood, no labels I have seen say anything of much use. The one I am looking at is used with 19000 for $30k
Thanks
Old Nov 10, 2006 | 05:56 AM
CUM4X4MINS's Avatar
Tell the dealer ship to look it up for you. They should be able to tell you that info.. but i have no idea where on the truck to look for it? someone will be able to tell you. some of the sevrice tech. on here and others.
Michael
Old Nov 11, 2006 | 03:21 AM
iaddiesel's Avatar
Any dodge mechs here?
Old Nov 11, 2006 | 06:05 AM
AirGrabber's Avatar
It should of been in the glove box. check again. If it not, Your best bet is to give the vin to dealer and have them print you up a build sheet. they can also give you a history report. Theres a fender tag on the pass side rad support but you'll need to know your #s to decode that.
If you go ebay yoou will see 06's brand new starting at $31995. Slt,4x4,cummins.quad cabs. plus, cheap financing.
Old Nov 11, 2006 | 11:59 AM
donhov's Avatar
As many have said earlier, there is no data sheet other than the window sticker on the 06's. Nothing informatiove in the glove box either any more. Differential ratios are based on standard items, if different it's on the window sticker (hopefully) and if it is an auto tranny it's a 48RE.
Old Nov 11, 2006 | 03:57 PM
iaddiesel's Avatar
Thanks it is an auto, with off road package and towing pkg, I will try the vin/dealer gig. Thanks
95yukon
Dec 28, 2007 04:36 PM
Awall
May 16, 2007 08:14 PM
PK
May 26, 2005 10:02 AM
adykstra
Oct 18, 2004 12:32 PM
jnaker
Aug 18, 2003 09:59 AM
