how to tell if upper or lower Ball J
how do you tell if the upper or lower is bad i can wiggle my wheel top to bottom if jacked up and can feel it in bumps a little. oh yeah 38,000miles thats bul@#$%^
That's about it for the test. But it would be nice to feel back there as someone else moves the wheel to determine if it's ball joints or wheel bearings.
I agree with rbertalotto, have a friend help. When I did mine you could see the movement in the hub, they were toasted. Had to do hubs and ball joints
Some play is allowed if you talk to a dealer.
Most front end shops will have a look for nothing. |
Jack up. Put big bar under tire pry up. Have some on look for play in upper or lower Ball joints. If no play there, porbably the hub bearings
