How to pop off rear door panel?
Old Jul 12, 2009 | 07:39 PM
sallyman1's Avatar
I have a 2004 dodge ram 2500. the right rear speaker and window button dont work. I assume its the wires in the rubber boot but how do i pop off door panel? where are the clips located? so i dont break them?
Old Jul 13, 2009 | 05:05 AM
sabersix's Avatar
TRIM PANEL
REMOVAL
1. Remove the screw that secures the interior door handle to the interior door handle actuator.
2. Remove the interior door handle from the interior door handle actuator.
3. If equipped, remove the manual window crank using a window crank removal tool.
4. Remove the screw that secures the door trim panel to the screw insert located in the center of the door.
CAUTION: The door trim panel is attached to the door by molded plastic retaining clips that are integral to the door trim panel. Do not pull the
door trim panel directly off of the door or damage to the trim panel and/or the power switch assembly will occur.
5. Lift the door trim panel straight upward to disconnect the molded plastic retaining clips from the door.
6. If equipped, disconnect the door wire harness from the power door switch assembly and remove the door trim panel.
Old Jul 13, 2009 | 10:15 AM
staarma's Avatar
Just pull the rubber boot back from the body of the door frame and repair the wires. No need to remove the door panel.
Old Jul 13, 2009 | 10:45 AM
sallyman1's Avatar
thanks guys
Doj Dewd
Jan 25, 2009 11:04 PM
dieselJon
Nov 21, 2007 05:53 PM
973604x4
Sep 4, 2007 08:18 PM
Stamey
13
Feb 12, 2004 08:04 PM
