-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   How does this happen?? Lost a tooth... (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/how-does-happen-lost-tooth-335301/)
westcoaster Sep 27, 2022 11:14 PM
Went to change my transmission oil and found this toothless wonder staring back at me....
Fordzilla Sep 28, 2022 08:02 AM
It looks like another example of living long enough and seeing it all...And apparently you're living right if you escaped damage free...:thumbsup:...Ben
Mexstan Sep 29, 2022 04:53 PM
In my opinion you are risking more (possibly catastrophic) damage if you try to glue that piece back on. The load on that area of the tooth is pretty high and I seriously doubt if any glue, epoxy etc has much chance of holding things together for very long. As Ben said, you got of lucky this time. Next time [whistle][guitar] Think that you have two choices here, drive it as and hope that nothing else breaks, or install a new gear.
Are you positive that there are no other pieces at the bottom of the case? When I look at the picture I see what looks like a gouge on the RH end of the damage. That makes me suspect that something else (FOD) got in there and broke the tooth. Also take a close look at the the end of the tooth above the chipped one. Is that a crack I see?
westcoaster Sep 29, 2022 09:56 PM
Plan is to run it for now and then take it in the new year to be rebuilt with a new gear.
