How to: DIY Transmission low speed shudder fix
9 Attachment(s)
we talked about it being a TSB over here:
https://www.dieseltruckresource.com/...d.php?t=226127 and basically, if you are out of warranty, it's gonna be a BUCKET of money. if you have the dealer adjust your tranny bands, it's gonna be...a BUCKET of money. if you have the dealer do your tranny fluid and filter...you guessed it. so you may as well put in a drain plug while you are in there. you can see my major spillage I had in one shot. i thought last time, that huge tin serving pan caught it all. TSB 21-009-07 Models: 2004 - 2007 (D1/DH/DR) Ram Truck (2500/3500) Overview: This bulletin involves the replacement of the governor pressure solenoid valve in the transmission valve body. Symptom/Condition: The customer may experience a 1-2 shift transmission hunt during light throttle application. This condition may be due to a governor pressure solenoid valve. Diagnosis: If the customer experiences the above condition perform the Repair Procedure. Parts Required: Qty. Part No. Description 1 04617210 Valve, Governor Pressure Solenoid 4 05013457AA ATF+4 Automatic Transmission Fluid AR 02464324AC Gasket, Transmission Oil Pon (Note: Original pan gasket is reusable and should not require replacement). 50 images here: draining the water from the fuel filter (notice i caught the pint of diesel and spilled the gallon of ATF), Attachment 74521 greasing the fuel filter o-ring, and the SQUISH of the grease showing you got the cap on the filter tight. Attachment 74522 here's the pan removed, I put the jack back about the middle of the door, so i had room to work the screws are REALLY long. Attachment 74523 slide the red LOCK back, then push the tab in to disconnect, and there is a white tab on the solenoid itself push on the snout of the solenoid to push the whole assembly off the block Attachment 74524 MSRP is ~$120 or so, dealer cost is around $80 or so. Attachment 74525 R2D2's uncle? http://i27.photobucket.com/albums/c1...r/DSC02638.jpg you gotta put the solenoid in the retainer plate to install it, and get the arm of the retaining plate over the black thingie on the end - the retaining plate holds the solenoid and the black thingie (that had the wires on it) Attachment 74526 "help" section in advance. this was ~$6. ATF-4 is $6 a quart. so if you can catch & re-use your fluid (I did this repair a month after I did the fluid & filter) you can save ~$35 worth of fluid. Attachment 74527 the magnet comes off the pan to clean it. I put the drain in the only corner that looked like it would not hit anything. I should have put it more to the center, it ended up being curved up too much, and i had to shape it a bunch with a hammer & anvil to get a good flat mating surface, then i ground all the rough edges off. Attachment 74528 i tightened it TOO MUCH and squished the plastic washer out (a CD Spindle washer could be used to replace it) I think a flat metal washer above the plastic would have distributed the clamping forces better, on the inside & outside. (i thought of that AFTER i had the sealant on there) Attachment 74529 i THINK this is the pesky loose coolant hose that leaks red coolant that looks like ATF. You have included 11 images in your message. You are limited to using 10 images so please go back and correct the problem and then continue again. |
this looks like a better fix, and about the same price
http://www.transmissioncenter.net/dodge.htm do a Control F (find) for 9-25-2008, and it will find this para: This kit was specifically designed to handle higher base pressure in high performance applications and to improve the reliability of the governor solenoid in normal use. In performance units the pressure can flood the Dodge solenoid and cause a no shift condition at full throttle. This is the fix. Fits all rear wheel drive RE model transmissions. Added 9-25-2008. Cost $149.00 I put the stock part back in mine...... and I still get a little tiny stutter ever once a while |
Originally Posted by 04ctd
(Post 2373736)
Good info so that did the trick huh?
Originally Posted by choppers555
(Post 2487968)
in some threads, guys have had several of the OEM parts put in (under warranty by dealer), and the problem persisted. |
so i have this problem going on and im scedualed to take it in tomorrow morning. Im still under basic warranty so i hope they cover the repair being i have a lift and tires... also, im going to un-download my tripledog tonight. hope that stuff doesnt effect my warranty
the tip for shift problem was a good one.
It took me SO long to get this resolved. I have had her in numerous times for this "shutter".
Finally the dealer replaced VB after performing the TSB and my prob is gone. Just FYI for those that the TSB has not fixed.. |
Oh guess what, this has not happened yet....It is not 10/1/2009.:o So if you are all really good this will not be a problem come 10/1/2009. Look at the date on his pics.[laugh]
hee hee...it's hard to get GOOD help...
FWIW, i took my other car into a tranny shop, and he said they no longer use the OEM part, they use one similar to the second post. |
giving it a shot tommorrow
where can i get that drain plug kit?
I think it was in the "HELP" section at advance.
just don't "gorilla fist" when you put it on, the washers will crush out |
i just performed this to my '06 mega. i repl. the solenoid and pressure sensor and filter. it fixed the shutter, but my tranny is still shifting out of 2nd at 2500 rpm, too high. i talked to trans. shop and they think maybe bands. i think modified valve body should work.
band adj.
had my band adjusted on outside of tranny and it shifts like new. evidently these really should be adj. every 30K or so according to trans. shop. adjustment was free.
