06 cummins 5.9 injector? issue
Hello all, I Just finished replacing #5 injector on my 2006 3500 5.9 24v diesel. Had bank two code. Injector tested at 22ohms. Finished job, new harness and injector.. All read less than .8 ohms through valve cover harness now. Started truck, cleared codes with ignition clear sequence. Started truck.. It runs exactly the same, no power..rough idle..won't even back up my slight hill of a driveway. Dash reads no codes, but check engine light is on. Please help!
dan123dbl
02-13-2015 05:47 PM
getblown5.9
03-02-2006 01:07 PM
